After updating WordPress to 6.9, I have a problem with the button style in posts. In the post edit box, buttons have their chosen width and color, but once published, these styles are not applied.
The problem also affects images that were previously centered and are now not.
Here is example: https://lifescience.pl/nadchodzace-wydarzenia/kalendarz-wydarzen-klastra-lifescience-krakow/
This reply was modified 9 months by
napster.
The buttons from posts should normally keep the settings that have been set in the article, but if on the single post template on button, there are set other styles, then those will overwrite those from the article editor https://i.imgur.com/GEobiUK.png or if is a standard template will aply theme panel settings – https://i.imgur.com/4y2l4yV.png
Also, I checked the problem with the iamge and now the image looks to be ok – https://i.imgur.com/ipzhhPK.png
napster.
I made some tests on my install, but for me it seems to be ok, maybe I do not make the same settings as you. In case you want, I can take a look, for this you can contact us via email at contact@tagdiv.com and provide a wp-admin access to take a look.
