Problem with Categories on Mobile Theme
Hello, love Newspaper. I’m sorted on desktop but having a problem on mobile. I’ve decided to use the mobile theme but I am having a problem.
1). The top level categories work great. You click in the menu and you get a nice simple listing of all the posts under that category
2). The problem is that all second-level (sibling categories) when clicked do not render a page populated with posts. If I move the sibling category out and to the top level then the mobile theme will render a page with those posts.
3). I’ve built the site to run off these categories and need the sibling categories to work on mobile???? Help!
4). If that is not possible I have found in the forum the code to remove sibling categories. But this only removes the siblings from the top of the 1st level page (above the grid) it does not remove the categories from the post
5). If the mobile theme does not work with sibling categories what is the CSS code to add to the mobile CSS editor to remove categories from all posts (including on each single post page). And of course not affecting the desktop display of the categories.
This is is the last wrinkle for me in my implementation. Any help would be awesome. Again great theme!
Cheers
b…
Please provide your website URL so I can take a closer look at it. The menu should works as expected including all the siblings’ category. Depends on what kind of menu is set up for mobile from the Menus section. Provide your website URL and some useful screenshots with the problem so I can identify it.
