Problem with category archives
Hi.
I am using Newspaper, with the Free News template uploaded. My website is https://polishexpress.co.uk. However, I have a problem with the category subpages, where the archive does not display correctly on desktops. Instead of three columns, I have one, and on top of that, the footer does not look correct, even though I also have the FreeNews template set up for the category sub-page.
Example: https://polishexpress.eu/category/irlandia/
Interestingly, the view when I am logged into WP panel is correct. Why is this happening? How to fix it?
Translated with DeepL.com (free version)
Please choose multiple columns for the row/inner row. For example in footer should be 4 columns: https://app.screencast.com/PDbmwDXmKtrCX
Drag and drop the elements in each column.
Thanks, but that’s not it, because I didn’t change anything in these settings, and a few days ago it was ok. I think I’ve solved the problem. The view is empty, one checked option in WP Rocket. It’s about “CSS Delivery Optimization”. It turns out that it can’t be enabled from Newspaper. Can someone confirm this?
If you deactivate the WP Rocket, then the issue is solved. Right?
The plugin is still enabled. I only unchecked one feature regarding CSS Delivery Optimization.
Do you have an up-to-date guide for configuring WP Rocket for Newspaper?
Unfortunately, no. It could be a conflict there.
It’s a real shame, how about someone taking a few minutes and putting together a tutorial like this on how best to configure WP Rocket for the Newspaper theme? I think a lot of people would benefit from that….
We will take into consideration your query for the future.
Thank you for understanding!
