Problem with category descriptions
Hi, in this example category
https://www.tindarobattaglia.it/recensioni/console-videogiochi/
I’m using the cloud template gadgets pro. The problem is that the description has for the first part the fonts used in cloud template.
In the second part (after first H2) the fonts change to the standard newspaper template.
Why?
Please edit the cloud template with tagDiv Composer, click on the element you want to edit it and adjust the fonts -> https://i.imgur.com/JEo4ei7.png
If this is not helping you, please provide some more details and screenshot from your settings in cloud template.
