Problem with changed the title articles
Hi, I’m having a lot of problems with the topic of indexing. 10 days ago I put newspaper theme but presents many problems. The first is the problem of dates in snnipets, my content is evergreen and the dates appeared, at the end I managed to hide them with the option to hide the dates in goal, but not always hide them. The second problem I have is that if you update the article .. You do not update the update date in the snnipets, that’s a serious problem of basic seo. And the third one I’m having a lot of problems when I change the title of the articles, I index them with Google search console with immediate indexing and do not change, they still show the title of the old article, it’s a very serious problem.
Hello Elevas32,
Regarding on your first problem, if you want to hide the date for modules and post pages, you can do this from Theme panel, like this -> https://www.screencast.com/t/Z2Bj7FP5XQ0y -> https://www.screencast.com/t/Z2Bj7FP5XQ0y
Please check the following topic here -> https://forum.tagdiv.com/topic/how-to-make-this/ and try to implement the last modified date as my explanation.
After each change, you should clear all your caches, purge all CDN files if you are using the CDN system and check the results. It will take a while until the Google will index the page because it is not a live effect.
