Problem with Child Theme
How can i setup the child theme correctly? I have created it (like you said in the documentation), but when i save the template setting for archive pages (for example to M16), the child theme just showing the default, not the saved one. when i activate the “mother” Newspaper, it is changed. Where is the problem? Can you please help me with the topic?
I just tested the child theme with settings for the archive pages (for example to M16) -> https://i.imgur.com/7MIAPqd.png -> https://i.imgur.com/cICsZb6.png -> https://i.imgur.com/RsbxeV6.png
Please provide some screenshots with the settings you’ve made for the child theme, also make sure that you are using only the child that coming with the theme version.
Hey Calin,
strange! Your screenshots look fantastic, I really can’t understand it. Where in the theme the setup for the modules is saved? I am using the original Newspaper Child Theme files from themeforest download. But now I have one simple question: I thougt the archive template is set for the “Home” as well – am I wrong with that? Where kann I change preferences for the home?
And i have to add: All other modules in my theme panel look fine, only the home / archive pages aren’t saved. isn’t it a strange behaviour? perhaps you have an idea / experience for that
If you are referring to the homepage, then I think that you have set the latest posts in Settings > Reading -> https://i.imgur.com/ICMqz89.png if yes, then the changes need to be done for the Blog and posts from theme panel -> https://i.imgur.com/Bi55M3r.png
If there is still a problem, you can send us an email at contact@tagdiv.com and provide admin login, as well as cPanel or FTP if possible. We will take a look. Include a link to this topic in the email.
