Hello tanzj,
Please provide more information about your problem. Also, you should provide here some useful screenshots where you explain your problem so I ca inspect it closer and also, so I will be able to provide a more accurate response. Also, provide your website URL so I can take a closer look. Also, if you are using some untested plugins, please try to disable all of them and install only the plugins that come bundled with the theme and rule out any conflicting plugins.
HI, i’ll try to explain better, on the home page with Chinese language (not latin encoder), the preview of each post description shows the full post, it does not stops after few words like in italian or englesh language.
The only plugin i use is “wpml” translation plugin. I suppose it is an encoding issue.
(How can i send you a screenshot?)
tanzj
You can switch the excerpt type on letters – https://forum.tagdiv.com/excerpts-introduction/
If you still have issues please provide your site url.
