Problem with cloud library > Cloud Templates > TDB TAG TEMPLATES > Tagged Posts
Dear Team,
I created a “Blank Tag Template” from cloud library. >>
and set it to Newspaper >> Template Setting >> Tag Template >>
Now the problem is on front-end when click to Exapl: Tag:”A” .. it suppose to show only posts that are Tagged with “A” : Like default “Tag Template” do.
But now when I click to any tag Exmpl:”A” it’s showing all the posts. No filter. It’s showing Tag: “A” “B” “C” all posts.
Is it problem with template or am I doing something wrong?
Kindly help.
Regards
Kapil
Now the problem is on “front-end” (I mean on website) when click to Exapl: Tag:”A” .. it suppose to show only posts that are Tagged with “A” : Like default “Tag Template” do.
It should display all posts that have that tag assigned. What happens if you use the default tag template instead of the cloud template?
For example if a post has 2 different tags, it will appear in both those tag pages.
Hi Simion,
That is what I am telling, “It should display all posts that have that tag assigned”
But it’s showing all posts which the “TAG HAS NOT BEEN” assigned too.
While the “Default Template” is working perfectly. “Default Template” is showing only posts that have been tag assigned only.
  • This reply was modified 8 years by kapson.
I believe the problem is here :
Here should be one option which can “AUTO INHERIT” the tags/or/category and show only posts which clicked on website.
I hope I am able to make my point what I need to say.
Best Regards
Kapil
That is a flex block, what exactly are you doing with it? Placing that block in a tag template will not cause it to display only posts with a specific tag. It will display posts according to the filtering you set for it.
So configure the block to display posts with a certain tag, if you want to use a flex block in a tag template.
Usually the post loop element is used in tag pages for example, this will automatically display posts according to where it is placed
– https://www.screencast.com/t/yP6E0HQUMxp
A block will only display according to it’s filtering, regardless of where you place it.
Thanks, I din’t knew about loop post element.
I have created it with loop and it’s working perfectly now. 🙂
Just one problem I see with Page Title > Title Tag (SEO) > H1-Default
It should show page title like this “Sample Tag Page Title”
But Instead It’s showing like this “sample-tag-page-title” on website.
I don’t find any setting here.
I think it’s conflicting with Yoast SEO? Just guessing.
Thank you
Best Regards
Kapil
I believe the title will be slug of the tag
– https://www.screencast.com/t/ksYDFX8bbbPu
– https://www.screencast.com/t/o07i8jmG
If the tag slug is made of multiple words they would appear with “-” between them indeed.
I believe something is not working as it should here, I will make a note of it on our issue list. The title should be the name of the tag not it’s slug. Thank you for mentioning this, it will be fixes as soon as possible. Sorry for the inconvenience.
