Problem with color-picker in Template Colors
Screenshot
The color picker, in the latest version, goes behind and you can’t use it.
We are aware of this issue in the theme panel after the latest update. It will be fixed as soon as possible. A temporary solution and a quick-fix would be enter the code provided below in this file (at the end)
https://www.screencast.com/t/c4g3SycbvA
.td-box-content-wrap {
height: auto!important;
Sorry for the inconvenience.
