Problem with color widget &change fonts
Helo. I have question. I can’t change color widgets on rigt slidebar. In link I included screanshot. http://www.czytasztosuper.edu.pl/wp-content/uploads/2017/03/problem.jpg
Red frame pointed elements with which I have a problem.
I tried to solve the problem of the settings panel and on css styles.
.td_uid_8_58b6d9ece4fe0_rand .block-title{border-color:#a6926d!important;}
.td_module_wrap .td-module-title {
font-family:display!important; }
Please help. Thank you.
You could change the color on the block titles in the sidebar depending on how you have the sidebar set. If you have a split row sidebar you can do it like this in Visual composer – https://www.screencast.com/t/ijcM3Ivgt or if you have a widgetised sidebar you can do that in Appearance->Widgets – https://www.screencast.com/t/lH4DA1lWh1Fhttps://www.screencast.com/t/v7U6IjSwQk
As for the post title on modules, I do not understand exactly what you want to achieve – https://www.screencast.com/t/XnXiadlyyua7 please provide more details.
