I’m new to the theme.
When I try to begin building a page, the column that is automatically added by TD Composer is misplaced, a little to the left, as shown is the prints bellow:
https://ibb.co/gXFg2b
https://ibb.co/enj8hb
Any help?
Regards,
Rafael
Hello rnpacheco,
It seems to be a problem caused by your untested plugins. Try to disable all of them, purge all CDN files if you are using Cloudflare, clear all the caches and check the results. If the problem is still there, try to make a new clean install from scratch, via FTP ay because this is the surest theme method, clear all the caches and check the results.
Hello Catalin,
Did all the steps you sugested and tried to create a new page, but the problem persists.
See the prints bellow for the alignment problem and active plugins.
https://ibb.co/cxQPQw
https://ibb.co/hbyNCb
Regards
