Problem with columns posts in Visual Composer.
I’m trying to replicate the format used in this demo of the site:
http://demo.tagdiv.com/newspaper/popular-people-who-everyone-seems-to-love/
I use Visual Composer with a custom layout of 1/6 + 4/6 + 1/6. I left in blank the 1/6’s columns, and insert a block text in the 4/6 segment. But the paragraphs don’t show correctly. What is the correct proportion? And when will be solved the problem with customs layouts in Visual Composer? 1/6 + 3/6 + 2/6 in full width it’s also broken.
The theme work only on those grid columns
  • 1/3 + 1/3 + 1/3
  • 2/3 + 1/3
  • 1/3 + 2/3
  • 3/3 – full width
If you use other columns combinations you need to adjust manually the grid because was not built from start to support those combinations.
All working grids are marked with blue color: http://screencast.com/t/CFrZyVSedt9
In post to build that layout like you see in the mentioned post by you, we use shortcodes from here: http://screencast.com/t/59reoQS2cO
Can you paste the full code for this post in your demo site, including text and shortcodes?
In the demo content of the theme none of the posts it’s similar. It Will help to understand the format options using shortcodes instead of Visual Composer.
The text from this post was formatted like this http://screencast.com/t/iOqBp99jkN using “Formats” tool from post toolbar. You can do it yourself using it like this http://screencast.com/t/tXNjj5ti
Here you have the post’s content: http://pastebin.com/Mnx6B7Nv
Hope this help!
Any Updates on this Topic about the supported Grid Layouts???
Would like to see that and need that.
As I mention above the theme works only on those grid columns:
1/3 + 1/3 + 1/3
2/3 + 1/3
1/3 + 2/3
3/3 – full width
Please let me know if this is not what you refer to.
