Problem with comments on page
I have authorized comments on page and posts.
I was able to customize appearance and apply translation for the comments on post.
However the pages still show the comment box without translation and style, and I don’t find the command in TagDiv to customize it.
How can I make so that pages show comments with the correct translation and style ?
Tanks in advanced,
Try to see if you can find those by accessing Newspaper -> Theme panel -> Translations -> Translations. There you can find a list with some words that you can translate in the right side of every words.
Hi Bettina,
I have already translated the comments, with Newspaper -> Theme panel -> Translations ->.
The problem is that this translations displays on posts only, NOT on pages.
How can I do to have this translation comments diplaying on both posts and pages ?
Thanks in advanced.
It should working even in pages.
Please verify once again if the settings are saved in theme panel.
Also, check for a plugin conflict. If this problem is not solved after that, then we need to take a look and see what happened there.
– admin url and credentials
Our team will take a look!
Solved, the issue was to enable standard pack: https://i.imgur.com/VX8PeJs.png.
