Problem with cyrilic fonts and video players
When i try to enter video from Youtube and Vimeo with cyrillic title, the title in right side doesn’t show correctly.
Look here: http://www.novinidobrich.com/
Im not using a CDN system. The result is the samo after clearin all the caches.
I have made a test on my website with your videos and the title of it seems to work as expected, as you can see here -> https://www.screencast.com/t/dMbev1ZVg0TB Most likely, the problem comes from your setup and your settings. Try to disable all of your untested plugins if you are using something like this, clear all the caches and check the results. If the problem is still there, try to make a new clean install to another sub-domain for testing and install only the theme and try making a new playlist video with these videos and check the results.
Hope this helps!
OK. Thanks for your support!
