I’m using the theme Default Demo and I’m in trouble, I scroll down to a sub menu appears, instead of having my logo or site name only appears in Newspaper, in the place where I choose what will appear I put another name and not Mute continues to appear Newspaper. like the image below
I don’t quite understand the problem you are having unfortunately. The screenshot you posted requires to be logged in – http://prntscr.com/ns8zwr
If possible re-upload so that I can see it, or even better post a link to the website so I can check it. Also mention what I should check exactly. Let me know.
follows screen capture link
https://www.dropbox.com/s/kzxwkg5gln1mx1x/erro%20newspaper.png?dl=0
From what I can see you are using a cloud header template. The sticky version of the header can be customized. While editing the cloud header template in the composer, activate the sticky mode, than you can customize the existing elements, or add/remove elements from the sticky mode – http://prntscr.com/o5wsuy
For the cloud headers there are 4 instances that you can customize, default desktop and mobile, and sticky desktop and mobile – http://prntscr.com/o5wtc8
On the other hand, if you do not want a sticky mode, removing all elements from the sticky version will disable it.
If you have more questions let us know.
