I recently purchased my newspaper7 theme, using the World News template. The problem is, my site does not show the buttons correctly, like the search button or the social medias buttons in the header. There is just a rectangle, showing E8or or error. My website for check (www.konterrevolution.at). What can i do?
Need help please,
Greetings Eric
Hello Eric_Vie,
First of all, please try to disable all the active plugins, leave just Visual Composer to active, clear all your caches and install only the plugins that come bundled with our theme and rule out the conflicting plugins.
I have checked your website in the mobile mode and I saw that you have the Chinese symbols instead of social icons and mobile menu. Usually, this kind of error appears when using CDN or loading fonts from a different source.
The solution to this issue is simple. You will need to add some code to your .htaccess file like this post suggests: https://forum.tagdiv.com/topic/strange-chinese-symbols-replaced-icons-and-arrows/
Hope this helps.
