Problem with display
First of all: FANTASTIC THEME!!! 🙂
But i have an issue on my category sites. If you click the link below you can see its empty field where it should be articles. I have set it to “infinite loading”. Can you please help me out? I want it to show a perfect grid without empty spaces.
Here is the link:
http://xtheme.firmatjenester.no/category/turforslagogreisemaal/
Hello Bjerknez,
This behavior happens due you have the post limit 10 for posts in your WP settings. So, as you can see, the ten is not divided by 3, and that’s why you will have 1 row with one post. So, if you want to avoid this behavior, please try to change that limit to 9 or another one which is multiple three, like this -> http://screencast.com/t/bRaS1ixw5
Ahhh.. off course…
Thanks alot!
Case closed and problem solved 🙂
