Problem with displaying images in the post header
Hello dear support team,
I’m once again struggling with tagDiv Composer and hope you can give me a tip.
I have images in different formats as featured images. Is there a way for tagDiv to scale these images automatically in the output? The column in which the image is displayed is always the determining factor. This only applies to the header area in the content block. No matter what I set for the image size, the output is always different. I’m giving two examples here. I have the same problem in the mobile view.
Example:
From my Homepage:
1. Picture in landscape-mode
This image would need to be displayed wider in proportion to avoid the image being cut off
2. Portrait-Modus
Here the image is also cut off, even though it is portrait mode
The header images on mobile are all cut off
I would be happy if you have a solution for my problem. Thank you very much.
  • This topic was modified 1 year by detlev.
So if I correctly understand, the situation is related to the featured image when you get on an article, for this, what can be done is to replace the Single Post BG Featured Image with Single Post Featured Image, in this way, the image will be full width, then just select the siez – https://i.imgur.com/eqtGZgX.png
Good morning Calin,
thank you very much for your support and especially for this solution proposal.
PERFECT! It works now.
I am glad that I chose newspaper.
Best regards to the entire team.
Regards, Detlev
