Problem with displaying most recent posts
I have a problem with my website not displaying most recent post on different pages like tag, category and on Flex Boxes on the main page. If I deactivate tagDiv Cloud Library, tag and category pages display the most current posts as expected. Same if I load another theme…
This has been ongoing for a few months since I installed this theme, I currently have the most recent version with the latest compatible wordpress version. I have disabled all other plugins and caching (cloudflare), to exclude plugins conflicts.
The block filters for my “Latest News” Flex Block 3 are as follow:
Category Filter: “–All categories–”
Sort Order: “Latest”
I have tried changeing it to “Random post from last 7 days” and the most recent post does appear sometime but when I select “Latest” again, it disapears.
All other options are empty or the default one.
Any ideas what is causing this issue?
If you are on a page, make sure that you do not have the option for unique articles enabled, if you have it please disable it.
Also, if you are on a cloud template and not a page, please make sure that you set the right filter. For example, if it is a cloud category template, you need to select the filter current category https://i.imgur.com/8HjGA8c.png, for tag, current tag.
Another settings that can be checked are the options for offset from the block – https://i.imgur.com/4ixKaTa.png make sure it is set only if you want to skip a number of articles.
Hi Calin,
Thank you so much for your reply.
The problem was the last item, the offset from the block option in the generals tab!
My 2 cents is that option should be in the “filter” tab, I would suggest you consider moving this option to the filter tab in future uptades.
Thanks again!
  • This reply was modified 9 months by randid.
I’m glad the problem is solved.
Thanks for the suggestion!
