Problem with displaying posts in a category
Hello
I don’t know what the problem is, but I’m having trouble displaying posts in newly created categories.
The new post is assigned a category and additionally a main category.
Unfortunately, when I open the link http://www.myurl.com/category/test/ nothing is displayed?
How it’s working?
Everything’s OK now
How did you solve this lukstan?
I have a similar problem. Will post a seperate post describing my problem in detail
Hi lukstan,
I’m glad that you manage to resolve the problem.
Hi HaraldOslo,
What you need to do is to make sure that you have at least one post in that category, after that, please check the category cloud templates, this can be edited using tagDiv Composer and in case you made changes on it you need to be sure that the posts loop element there is no offset set – https://i.imgur.com/Zmpt4lH.png – https://i.imgur.com/gfBTQq4.jpg also if you are using blocks or grids make sure that the filter is set on current category – https://i.imgur.com/RwpZE7r.jpg
