Problem with EXCERPTS
I have a problem changing excerpt in Block 16.
I can change ‘title’ but changing ‘content lenght does not make any difference. The affected website is:
Pokertexas.net screenshot
Would you be able to help, please?
Regards,
Hello ImSoCute,
Please check your theme panel and check what kind of settings are checked, as you can see here -> https://www.screencast.com/t/yhluBYtfI For more information about Excerpts option, please consult here -> https://forum.tagdiv.com/excerpts-introduction/
Hello Catalin,
Thank you for your answer, however I consulted documentation before I reported the issue.
1. I confirm I have selected ‘On Words’ Screenshot_1
2. There is no settings on Module 6 regarding excerpt length (just title lenght), however…
3. There are settings on Module MX7 regarding both title and excerpt length and also clearly shows td_block_16 on there. Screenshot_2
4. As I have mentioned in previous post It is possible to change title length by amending options on MX7 (which means I changing correct one) but it has no effect at all when changing ‘content length’
Edit: additional info:
I simply want to achieve this look: https://demo.tagdiv.com/newspaper/block-16/
Instead of what I have now: http://prntscr.com/f39pb9
Thanks for understanding.
  • This reply was modified 9 years by ImSoCute. Reason: added additional info what I want to achieve
Hello ImSoCute,
The block 16 uses more modules, depends on where exactly this block is used. If the block is used on sidebar, for example, is used the module_6 which do not have an excerpt and for the other sizes, is used the module mx_7 which has the Excerpt option and which can be found here -> https://www.screencast.com/t/o7DoOo3Tv
Pay attention with our modules/blocks.
Hello Catalin,
You are not very helpful at all. Please read with understanding. I never told you I’m trying to use this in the sidebar. I clearly described the issue I have and what I want to achieve.
If you are not able to provide working solution, can you escalate the issue to someone who actually is willing to help, please? That would be greatly appreciated.
Regards
Hello ImSoCute,
Please send us an email at contact@tagdiv.com with your log-in information (wp-admin) so we can further inspect it closer your Excerpts section. I need to do some deeper investigation so I will be able to provide a more accurate response. Provide there the link to this topic so we can quickly identify you.
