Problem with excerpts
Hello. I use tag <more>, but its dont work on index page. Where is my mistake?
Site: http://loren-ditrich.ru
Unfortunately that option will not work with our theme. Our modules and blocks use custom made excerpts that are controlled by the theme and you can set their length from the theme panel: http://screencast.com/t/O6jTY85NK – https://forum.tagdiv.com/excerpts-introduction/
As an alternative you could use block 12: http://demo.tagdiv.com/newspaper/block-12/ which has a read more button at the bottom.
