Hello
Is it possible to get the code in database?
http://s26.postimg.org/68bkjvb6x/screenshot_7242.jpg
Thanks for help.
The Export/Import feature affects only the options in the theme panel. It is useful when you are moving your website for example, then you simply copy the code from the respective section and import the settings on the new install. Or for periodic backups maybe.
There is no setting or option in the theme to export or import data from the database
– https://forum.tagdiv.com/import-export-theme-settings/
