Firstly sorry for my bad english.
My problem is that since I installed Newspaper 8, when I post an URL of a post on facebook, on the social media the post doesn’t show a preview.
I try to use Sharing debugger of facebook but it shows me the following issues:
The 'og:image' property should be explicitly provided, even if a value can be inferred from other tags.
The following required properties are missing: og:url, og:type, og:title, og:image, og:description, fb:app_id
Can you help me?
Thanks for your reply. My site is http://www.motoristes.cat
You basically need to have open graph tags added to your site, typically with a plugin like Yoast SEO or similar.
It is true that a few days ago I update the Yoast Seo plugin. Now I am looking how to open graph tags but I don’t see the option.
Do you know where is it?
Yeah. Also note every time you update Yoast SEO, be sure to check the ‘features’ page as they sometimes turn stuff ‘on’ by default, even if you don’t want it (like ‘count links’) or similar. They have also added new ‘user roles’ for SEO Manager to the WP dbase without asking if we wanted that. I posted a [tutorial] around here on how to turn that off with a function.
Anyway, glad you got it sorted! 🙂
Does using the premium edition of Yoast make any difference?
I’m struggling with getting the preview on a post in Facebook. Sometimes I get 404. The facebook debugger tool says that I dont have og:image tags or og:description tags.
I’m using Yoast free edition.
Thanks, James.
