When I click “get access token” (facebook) in the Social Counter it freezes and I can’t get this token to validate the number of followers in facebook. I get the ID app and the Security Key from my app admin panel at facebook developers page.
Other social networks are working fine as instagram or twitter.
I have tried from another browser and same issue happened.
¿Anyone know where could be the problem?
Hello utzgurx,
Furthermore deeper investigations, we have noticed that it was a problem with some js from this plugin and we have fixed it in a new plugin version. You should take it from here -> http://cdn.tagdiv.com/wp-content/uploads/2017/03/td-social-counter.zip the new version of Social Counter. Remove the old version and install it on your backend. Also, you should clear all your cached images and files from your Chrome, like this -> https://www.screencast.com/t/5bbgsp85O and check the results.
Hello utzgurx,
You should go to the Plugins section and from there you simply disable and remove the Social Counter. After this, you should Add New plugin from Plugins section and load the file which I gave you above and install it at your backend.
Hope this helps!
My Access Token still does not load after suggesting to download and install the new plugin and removing the old one.
I’ve cleared local and server both caches.
Please suggest.
I also have this same problem. I have deactivated the plugin and installed a new version of it. When trying to get the security token the plugin tried to load it and nothing happens
We can’t generate Facebook access token…
The Social Counter is not working after an update
I have purged the cache
When I click Facebook Access Token Get Access Token it just says ‘Please wait…’
But nothing happens
https://www.dropbox.com/s/84eosvi6h9jupbw/error.png?dl=0
Got the same problem. Was told to get the latest version of Newspaper, which they said was 7.8.1 — but my GoDaddy version of Newspaper, which is GoDaddy’s latest I believe, is 7.5. Could that be part of the problem?
This reply was modified 9 years by
RawFoodGuy.
Please note that there can be some delay for the data to refresh after successfully setting up the social counter accounts. If you still have problems, maybe something else is interfering with this process. Try disabling all your plugins except Visual composer and the social counter (make sure you have the latest version from the theme package) clear any caching installed and try again. This is working properly on our end, and so it should be for you.
Thank you for understanding!
@eugqua Please send us an email at contact@tagdiv.com and provide admin login information, so we can investigate further why this is not working for you. Also paste a link to this topic, so we can identify you.
Please try to understand that this issue with the social counter is now fixed, and it is working properly. All you need to do is to download and install the latest theme version and use the social counter plugin from this package. Then it is very important that you clear the browser cache as instructed above, if you cannot generate the Facebook token.
@m0000g Please send us an email at contact@tagdiv.com and provide admin login information so we can investigate. Also provide your social counter Facebook configuration (Facebook Id, Facebook App Id, Facebook Security Key).
