Problem with feature images in posts
Hello my site is “https://sustainabilitynext.in”
There is a problem in posts page, for example, have a look at this post “https://sustainabilitynext.in/book-review/benedicts-book-review/hot-book-on-how-to-cool-india/”
As I create a post and apply “Style 1” in posts template and publish it.
The preview looks good, but below the featured image there appears as there is one more image with the wrong link.
Can you please try to help me to remove this extra entity.
regards
H.S. Ganesh Keerthi
From what I can see this image do not longer exist on your website -> https://i.imgur.com/6U1FMJB.png -> https://i.imgur.com/dvypcXv.png if I’m right this should be set in theme panel > ads on post template style 1 and add/banner like this -> https://i.imgur.com/axviSq9.png -> https://i.imgur.com/Sgp8WHF.png so in order to solved the problem, you can replace the link for the banner or remove all the code ( remove the ad ).
Hope this will help you, let me know the results!
Thanks a lot
It worked, I could remove the extra element
regards
H.S. Ganesh Keerthi
