Featured images, both desktop and mobile versions, do not fill the Big Grid. How can I solve this?
Screenshot: https://imgur.com/a/XmMaWyt
Link: https://www.lacasadeel.net/
This topic was modified 6 years by
Beldar.
You can fix this problem using our guide from here -> https://forum.tagdiv.com/thumbnails-fix-strange-looking-images-on-blocks/
Hope this will help you!
I see that there are some improvements for desktop -> https://i.imgur.com/v8eMbtd.jpg
Also I see that you are using some optimizer for images ->https://i.imgur.com/0GIZTik.png is possible have something to do with the thumbs that your images are not displaying correctly.
Please disable all non theme plugins and check the results.
Let me know the results!
I turned off the options related to the images in the Jetpack plugin and it worked during this week. But again the main image look bad, with the options removed.
Example: https://imgur.com/a/MxwAXS6
I think that you are referring to this -> https://i.imgur.com/lRf2053.jpg this problem is that your image do not have a thumb for that module, you can fix this using our guide from thumbnails from here -> https://forum.tagdiv.com/thumbnails-fix-strange-looking-images-on-blocks/
Hi Beldar, is possible to be because the image that you upload has a lower size then the biggest thumb that you are using.
Please make a test and upload an big image and see if this is still displaying like that or has a proper thumb.
If the problem persists, please try again, but this time only with tagDiv plugins enable.
