Problem with featured images
I’ve already tried with Regenerate Thumbnails but it didn’t work. How can I solve this? (Block 14)
https://imgur.com/a/6HCEY
  • This topic was modified 8 years by viglioh.
This would happen if the images were too small. Check their size. The blocks don’t stretch them.
The second image you see it’s 1672 × 941, so I guess this isn’t the problem
Sorry – have you modified the width of the block? Block 14 normally isn’t that wide and the thumbnail width looks normal for its default width. You would need to “stretch” the featured image with CSS as well or force the block to use different size thumbnails, but you’d have to mess with the theme for that.
Block 14 uses 356×220 thumbnails.
No, I only changed the Row’s layout with the 1/2 + 1/2.
From the docs:
“There are 3 ways a block can show content:
On a full width row, on a 2/3 row, and on a 1/3 row.”
So I can’t use this combination 🙁
Thanks a lot, can u help me in this: https://forum.tagdiv.com/topic/rounded-featured-images/ ?
There is no theme setting for that specifically. It could only be done through CSS code. Remove that code and try this one for example
.td-module-thumb, .td-module-thumb img, .td-big-grid-post {
border-radius: 10px!important;
Thanks a lot, now works!
