Problem with filter by tag
I’m trying to display certain posts in a block, filtering by tag, but the block does not display any post.
I have assigned a tag named tag1 to a post and I have wrote tag1 inside the tag by filter field.
Where do I mistake?
Here 2 screenshots just to show you…
null
null
If the tag slug is the same as the tag title itself, there should be no problem filtering the posts by tags in a block element. In my tests there is no issue with the tag filter
– https://www.screencast.com/t/CLN9Ep5wZdEI
– https://www.screencast.com/t/6pLP9vnOqn
