Problem with filter
Hello. I need use filter by categories tag but have not effect in the frontpage.
And where are you using the filter if it’s not affecting the homepage? You need to edit each block and use the block settings to filter posts the way you want them in each block in particular: https://forum.tagdiv.com/block-settings-guide/
