Problem with flex block 3 responsive
Hi, i’m developing a news site with newspaper template, everything is fine except for a bad display in responsive mode of flex block 3. The last two items are stick together. what can I do?
  • This topic was modified 6 years by miil.
Hello !
We have tested this on our side and we cannot replicate your issue.
Hi Vlad,
I’ve deactivate all plugins, i do not use child theme or cache plugin, but i’ve the same incorrect view.
Thank you
Hello !
– admin url and credentials
– cPanel url and credentials
Our team will take a look and help you with this !
