Problem with Font on Post Page
I updated to latest version and changed my post content font to Alegreya Sans from theme panel >> Theme fonts >> Post Content but it is still showing the default font.
Hello hadharm,
It seems to be a caching problem. If your caching plugin is too strange it may occur this. Try to clear all your caches, purge CDN files and check the results. First of all, please ensure that you have added your code to the correct section and also, make sure if the style has been successfully added to your panel.
I have cleared the caching and I am not using CDN but it is still showing default font. See demo here https://goo.gl/CzxXcC
If this is unresolved yet kindly help me with changing the font making use of CSS
The problem you are facing is probably because your post content is empty. You content is grabbed from another source maybe through a script? only you can know that, but there is no standard post content: http://screencast.com/t/R5SlUmjIZ1C In this case the font is defaulted to the standard body->p font which is verdana. Try to change the body general font: http://screencast.com/t/ykJSkXBkVb
The body general worked. i tried to restore my backup 7.4 and everything is normal. That implies that the update is causing the problem
Well we have no reports of this. None of our users complained about changing fonts when updating the theme and we have not observed anything of the sort. There were a few changes in 7.5 and this could affect your site in particular but it does not mean it affects everyone. As I said above, your posts are not standard posts. Even 7.4 should not handle the font from the post fonts, but from the main body fonts because your post content container is empty.
I am trying to put the below code in mobile custom css but the font is not changing. Pls test this from your end.
.td-post-content {
font-family: "Alegreya Sans";
line-height: 30px;
font-size: 16px;
font-style: normal;
A font change cannot be done with css without loading the font first. When you switch fonts in the theme panel, the theme also loads the font so it can be used. With this css you do not load fonts, but only specify which one to be used. If you want to use the font with css you will have to download the Alegreya Sans sans font as place it on your server and use this code:
@font-face {
font-family: 'add your font family here';
src: url('add the source url for the font. insert the path that leads to the font') format("opentype");
font-weight: normal;
font-style: normal;
Okay THanks
