Problem with fonts after 10.3 update
Hi. All of the fonts seems to be locked in at 400 after the latest update (10.3) (https://ibb.co/3M0JbQM)
They can get thicker than 400, but not thinner. I´m usually going with Roboto and 300 in weight, but that is impossible now.
Best // Karl
Please check to see if you are not using a single post template from tagDiv Cloud Library, on the cloud templates the settings from theme panel will not apply, only on standard templates, the single post template can be edited with tagDiv Composer like this -> https://i.imgur.com/t9vUx7l.png
Let me know the results!
Hi again, sorry for the late reply.
I dont use any templates of that sort, at to my recollection.
https://prnt.sc/rhukyu
Please check in theme panel if the support for the font weight that you want to use is enable -> https://i.imgur.com/wj2eZL9.png by default it is only for 400, also make sure that you clear all cache after you save the settings.
Great. It worked! All of the alternatives were unactivated but I swear i havent touched them. Should i activate the one I do not use, i.e. 200, 400 etc?
We recommend to activate only the fonts you are using.
If there is anything else, that I can do for you, just let me know!
Have a nice day!
Thats all for now, thanks for helping out..
