Problem with fonts and maps in the visual composer
Hi ,
I have 2 issues:
1. I just changes the font size in all my posts and noticed that in all the posts that I edited with visual composer the first paragraph has not changes and the font remained the same as before the change I have made. the rest of the post is ok but only the first paragraph still has a different font size (as before the change). please see image url below of the code and the post as it looks live:
http://pasteboard.co/qgpNJDu.jpg
http://pasteboard.co/qgny2Kj.jpg
2. In all these posts (that I edited with visual composer) The google map is not working and the map title is black.
I tried a few times to change the map url but it still doesnt work. please see images of the code and how it looks live:
http://pasteboard.co/qgMRUFv.jpg
http://pasteboard.co/qgNTUfg.jpg
Thanks in advance!!
1. The font settings from panel will not be applied on your post if you use Visual Composer on post as the theme supports Visual Composer on posts but doesn’t have css for it. It will work like the text block works on page content. You will have to use inline css or add an extra class to the text block and use custom css to change the font. The panel settings will be applied only if you create your articles using the default Visual Editor(No Visual Composer) – http://screencast.com/t/ecGYOzpX
2. If you use the google maps block try to use an iframe – http://screencast.com/t/vEOVQ65EsVU – http://screencast.com/t/wTrvjFPAHZ
