Problem with footer and somes pages display
Hi.
When we work with the Composer the footer are displaying perfectly but when in use the website don’t show some categories or pages correctely:
– The footer = http://www.casactu.info
– The 404 pages = https://www.casactu.info/dfgs
– 1st footer not displaying properly whan an article is displaying = https://www.casactu.info/succes-de-musiba-comment-dip-a-pulverise-les-records/
thanks in advance for your help.
Indeed it was a problem, but now is fixed, and you need to deactivate the tagDiv Composer plugin, delete and re-install it again from Newspaper plugins => https://www.screencast.com/t/WLy01lbc
Thank you for understanding!
Hi.
It’s not working. I’ve already made the modifications you mentionned.
The 404 and search page works well => https://www.screencast.com/t/07SUuRzL -> https://www.screencast.com/t/OqBEb2V80
Also, for the footer, the problem may be due to a plugin conflict, so please please deactivate ALL plugins except tagDiv ones, also if you are using a child theme or cache plugin, deactivate them, clear all cache and try again. There may be a conflict between WPBakery and the tagDiv Cloud Library.
Please notice that we strongly recommend using only one of those plugins with our theme (WP Bakery or tagDiv Cloud Library, but not both).
Let me know about your results!
Thanks you right it’s AIO SEO that caused conflict with the but.
It remain on problem. In the posts the prefooter is not displaying properly : https://www.casactu.info/medias-macky-sall-appelle-a-accelerer-les-reformes-relatives-aux-entreprises-de-presse/
Thanks in advance.
Hi @syndiaye,
Please send an email at contact@tagdiv.com and provide wp-admin, so we can investigate this issue. Also paste a link to this topic so we can easily identify you.
Let us know and we will gladly assist you.
All work fine.
Cheers 🙂
