Problem with footer edition
Hello, I have a problem when trying to edit my footer, I don’t get the options that before if they were where I could modify everything related to the footer… maybe there is a new option to activate it in the latest versions?
Thank you
I attach an image:
https://drive.google.com/file/d/1ttw2r2Gezb3Q11wyRUz4IUnFhDwzxdnG/view?usp=sharing
Hello @editamagerit!
Normally, if the option no template is selected, then you should see the settings there.
Please make sure there is not a plugin conflict with our theme. Deactivate ALL plugins except tagDiv ones, also if you are using a cache plugin, deactivate it and see the results.
