I’m building a new website with the Newspaper Theme (I have been using it on another website for a few years now).
With this new website, I have a problem with the footer :
– In the Theme Panel, there are no settings in the footer section
– When I import a footer template, there is no “Edit with Tagdiv Composer” link in the templates section for the footer (no problem with other templates like headers, singles, pages…)
– Moreover, when I try to import the “Art blog pro” footer template, it seems it imports a full page without any footer
Is there anything I’m doing wrong?
The website url is http://www.antiquark.me (currently set with no footer)
Thanks for your help
Please check this video: https://www.screencast.com/t/fGV2uwNO2I
You can assign and import from Website Manager which footer template you need.
If you have a cloud/PRO template, but you can’t edit the footer, then edit your homepage with TagDiv Composer, scroll till footer, click on footer zone and you can edit/delete the elements there.(see the video)
Hope that helps you!
Thanks for your answer, I’ve tried and it works.
But your Art Blog Pro footer template seems to be broken : from the Website manager, when I import the Art Blog Pro template, it adds at the bottom of the page something which seems to be the Art Blog Pro homepage instead of the footer template.
Could you please correct the template and let me know?
Please edit the footer template delete the code and add this code https://pastebin.com/efnE47Cu after save it and assign it on the page.
