I still have a problem with the footer menu.
I use the footer of the “World” template and have now installed a new footer on the home page that I like. (“Amber Light”). However, the new footer is not displayed on the subpages. The footer of the “World” template always appears there.
What do I have to do so that the “Amber Light” footer is displayed on all subpages?
Thank you for your support.
Christiane
Please check if you have set the footer template globally -> https://i.imgur.com/Qx26uL8.png
