problem – with front-navigation
HI.
Attached:
https://www.1000wordsmagazine.com/wp-content/uploads/2018/03/probelms-1000wm-ajax.jpg
A few problems – errors appear on the website, since today morning.
– ajax search not works – on the top right. – not in any browsers.
– menu items which overlap each other – sub-menu cannot click-catch – because of gone-away if you try.
– pictures on site – flat not correct size shown – featured images – flat – looks like missing size parameters.
– pictures in articles should open big-wide-modal, but instead – open the picture URL redirect. – meaning visitor took away —> causing bounce rate big.
How to check admin-ajax.php if its working or not?
Was everything good until 1:00 am today – when I added a new article – then went to sleep. – I did nothing else.
What happen since? –
Problem with cache or CDN?
I did not touch any plugins since 10days – and was ok until today.
Could you give any advise – or could you check it for me – whats wrong?
Thx, Zoltan
I have checked the website, for me the search works properly and the images are displayed fine, see here
https://www.screencast.com/t/LtYpBAyPQ
The menu items overlap, they are placed on top of each other. It is hard to use them properly. You could stretch the menu to accommodate all the menu items
https://www.screencast.com/t/Z1XwoXqbRR2
