Problem with Google Fonts
I can’t find Jost font, when customizing blocks -> example. Any help?
  • This topic was modified 6 years by jakubz.
Hello !
If you cannot find a font you can add it manually as you can see in our guide here: https://forum.tagdiv.com/font-customization/
I know about it but I need more than 5 custom fonts
Hello !
Unfortunately the theme limit is set to 5. For more options you can contact our custom work team and they will be able to help you: https://tagdiv.com/web-development-services/
Well I’m not going to pay for custom work because you offer google fonts support by default -> screenshot
Please fix it because Jost font is in google fonts’ library
Hello !
I am sorry but I don’t clearly understand what you are trying to achieve. Do you already have 5 custom fonts and Jost would be the 6th ? Or you are having problems simply implementing jost ?
Maybe it wasn’t clear so I will try to explain it:
I want to use one of the Google Fonts – Jost. I can’t find it on the list (attachment). So I use custom fonts – Jost 300, Jost 400, Jost 500, Jost 700 and Jost 400 italic. Now it turned out that in my design I need more Jost weights (e.g. 100).
All you need to do is just update of Google Fonts list with Jost 🙂 (attachment)
Hello !
I have downloaded the font from here: https://fonts.google.com/specimen/Jost?query=jost
Converted it as you can see here: https://www.screencast.com/t/6NKQ2CJcE and uploaded it.
The font added can be found at the top of the list and all the sizes are working: https://www.screencast.com/t/v11Yz0ona
Let us know if you followed all the steps above and if this works.
I tried it – I used fontsquirrel webfont generator and it doesn’t work. Here is how different weights look.
Hello !
– admin url and credentials
– cPanel url and credentials
