I have checked website on gtmetrix and there is warning there that says serve scale image. All those images are related to instagram. Then I have to check on website it loads instagram images almost double size larger then it display on the page. How to fix this issue?
https://www.screencast.com/t/kZloX1y1
Yes, there is a css that resize all Instagram images to can have the number of images set in theme panel, in order to have the normal size you’ll need to set the numbers of images on default -> https://www.screencast.com/t/rAAUrtTqd4 -> https://www.screencast.com/t/fCM0nCMBDK
Thank you for you understanding!
