Problem with header ads viewability
Hallo, we have a problem with header (and all other places) with ads.
We have adnxs code, with adsense and in house ads but when we want only have them at desktop (DISABLE ON TABLET LANDSCAPE ,DISABLE ON TABLET PORTRAIT, DISABLE ON PHONE is enabled).
But at our stats we have the display code for mobile but its hidden. We cant see the ads but we have the pageview at ads statics.
Its possible to enable and client-side detection and server-side device detection like we have at ad insterter wordpress plugin?
Our website is http://www.topnews(dot)gr
  • This topic was modified 8 years by amd4ever.
You could use a different ad implementation then the theme’s, through a plugin maybe like you mention. Indeed the theme will hide the ads for the devices you choose not to display them. Try experimenting with plugins or server provided services if this is a problem for you.
We want the ad at header (with background colour set from newspapers settings). Its not possible with plugin, only from newspapers settings
Most users that want more advanced ad settings recommend the Adrotate plugin. This is compatible with the theme based on user feedback. then you could use that plugin in combination with the theme ad spots. Here are some guides if you would like to try
– http://www.wpbeginner.com/plugins/how-to-manage-ads-in-wordpress-with-adrotate-plugin/
– https://ajdg.solutions/manuals/adrotate-manuals/
Its possible t ad code for header with code at newspaper template and not with plugin?
I don’t quite understand what you mean. The theme has a header ad spot in which ad codes can be used
– https://forum.tagdiv.com/header-ads-adsense/
