Problem with header ads
I’ve some trouble with my header ad, it’s not at the right place and doesn’t use all the space.
When I disable the ad for mobile, it doesn’t display anymore on any device.
It seems to load the mobile sized ad on every device.
(I use style 1)
Header ad problem
(I framed in red the ad)
Could you help me ?
EDIT:
I updated the theme, I’ve the same problem but at least the ad is at the right place.
Please provide a link so I can inspect this.
Here is the link:
http://kinits.com/hvdv/
(You need to use the code “kinitsverdon2015”)
Thank you
Please try to set size for ad from Theme Panel – http://screencast.com/t/FGqZmjxKKd if this doesn’t work maybe ad has a specific size in code. Also please try to display it in other sections(article inline, bottom…) and if you still have issues.
Also deactivate all plugins and leave only Visual Composer active and check again.Also note that adsense are not responsive on the fly, you have to refresh the window in order to get the right size ads for current screen width.
Ok, I desactivated all plugins and it worked.
Then I reactivated them, annnnnnd… it still work :O
