Problem with header article
Hello guys,
I’ve accidently done something, that messed up my website. The adress is vogulepoland.net As You can see, at the top an article appears, and i don’t know how to remove it. Please help.
Best regards
That would be the homepage post element, maybe you have added that to the page
– http://prntscr.com/m59fzm
To remove it you can edit the page and delete the homepage post element.
The homepage post will display one post at the top of the page, the featured image is set as background
– https://demo.tagdiv.com/newspaper/homepage-one-top-post/
