Problem with Header on Category page
Hi Support team,
I created header with Cloud template and applied it on Theme Panel
It looks good everywhere except Category pages, where Header looks like it lost all its CSS
How I can fix this?
Please provide more information, screenshots and your website link in order to help you.
Hello Betina
I cannot provide links because it’s on Maintenance mode now
Here you can find screenshots
how header and footer should look like
Main page with header based on cloud template
https://photos.app.goo.gl/CBaJssPSfNCYm58n9
Main page with header based on theme template
https://photos.app.goo.gl/qJoqFmEiUrxS1tGi8
How header and footer look on category page (author page and maybe others)
https://photos.app.goo.gl/Kt1sPTnU6secQ5vn7
https://photos.app.goo.gl/ssSV2zDMLDYU9gV9A
The same page in editing in composer view looks ok
As I see it’s theme header and footer without CSS
1. disable TagDiv Composer
4. install TagDiv Composer
5. activate TagDiv Composer
Please check if you have active and you use the tagdiv CSS Analyzer, click on “Remove generated CSS” and see the results.
If the problem is not solved after that, please start looking for a plugin conflict.
Hope that helps you!
Thank you, Bettina
This workaround fixed the issue
