Problem with "Hide page in devices"
I just updated my newspaper theme to 8.1 (Deactivated and deleted the theme, and uploaded and activated the updated version) and now my pages are the same in all devices. I had some blocks hide in mobile devices, and others in deskopt, but now all of them appears in both and I cant change it.
Also, I tried to install the mobile plugin to try other option, but its not working. Its installed and appear the Mobile tab in the theme panel, but doesnt work.
I deactivated all plugins to check if was something wrong, but same.
http://frikedades.com/
When you updated the theme to the latest version, the tagDiv composer was automatically activated
– https://forum.tagdiv.com/tagdiv-composer-tutorial/
This composer can cause Visual composer elements or features to not work properly, so you can try to deactivate it and check the results with the hidden blocks.
The mobile theme seems to be working at the moment, I see no problem with it
– https://www.screencast.com/t/Wd6uUEG3Q2J
