Problem with homepage
since months I have problems with the visualization of a module in homepage.
It’s a default module form Newspapar travel, the last block goes on another row while from Tagdiv editor I see evrything perfect and I haven’t changed nothing.
How can I receive some help?
Thank you
  • This topic was modified 3 years by steffi83.
Hello @steffi83 !
In order to avoid misunderstandings, please provide more information(screenshots/video) about what exactly you need to achieve or what is the issue there and your website link.
Hello @steffi83 !
When I install the demo, I get the right elements: https://prnt.sc/V4GYU9WkUmPi in composer and frontend as well: https://prnt.sc/diG31niG9LMB
Sometimes, the issue can be caused by a plugin conflict or a cache issue. That’s why we recommend deactivating ALL plugins except tagDiv; if you’re using a cache plugin, deactivate it, clear all cache (including from your browser), and then check the results.
Let me know the results!
Thanks but I can’t deactive all the plugins… wordpress works on plugins, and some are crucial
