Problem with Homepage and Tag Div Composer
Hi there,
I am experimenting with the different theme demos (without demo content).
When I try to make a nice homepage with blocks and edit it in the tag div composer the work space seems different than it should be. E. G. there is no possibility to save the work…
Please check attached image on the given webpage Watch Screenshot…
Whats the problem?
Regards, Chris
It seems that something is covering up the composer’s default options. Maybe a plugin is inserting itself in that section and causing this problem. The tagDiv composer does not have those options there. I suggest you try and disable all your plugins except the composer. This should remove the issue. Then enable them one at a time, to identify the one responsible.
