Hi there,
I am experimenting with the different theme demos (without demo content).
When I try to make a nice homepage with blocks and edit it in the tag div composer the work space seems different than it should be. E. G. there is no possibility to save the work…
Please check attached image…
Regards, Chris
Please disable all plugins except the page builder, clear cache and reset cdn files if you use it. Please also check any custom code you might have added to the theme panel or the theme files. If you use a child theme, please switch to the main theme to make sure it does not affect the proper functionality of the theme.
Also please don not use both page builders at the same time. If you use tagdiv composer, disable visual composer and vice-versa.
