I have a problem executing an html code for a button. I use one script for tidio plugin, which place after the footer (in theme panel/JS-Analytics. I have an html code that should run after a button is clicked. When I use html code for the button in the normal wp builder – I have no problem. If I use the tagdiv composer button and put a class, it only works on desktop version. On mobile version it doesn’t work while the code in normal wp builder works on both desktop and mobile version. The code is the same for button.
Do you have any idea about this problem?
